We are going to start building an FAQ like we have in all the sections to help users find key information on the SideWinder. If you see things that needs to be added like , ride reviews, tech info , modification or anything that will help a SideWinder owner please PM me or one of the mods. Remember this is a work in progress. FYI some info listed may cross over into the SR Viper so be aware.
NEW SLED INSPECTION/MAINTENANCE
PRIMARY AND SECONDARY TORQUE SPECS
EASY WAY TO CHANGE YOUR OIL
SHIPPING SPEC SHEETS
CLEAN YOUR AIRFILTER RUN IT DRY PER UPDATE
CHAINCASE ADJUSTMENT UPDATE
Paint Codes
Skis
Step by Step EPS Install on 2017 to current Sidewinders (includes parts list and EPS Harness info)
SKI OPTIONS, TUNERSKI
PILOT 6.9 INSTALL AND SUSPENSION TUNING BY ROCKERDAN
Tracks & Studding
Installing Tunnel Protectors
Studding your SW by CB Performance
2017 Tracks Lengths, Drivers and Gearing
Understanding Track Length and Pitches
Studding
SUSPENSION
QS3 Suspension Set up for LTX-LE
FLOATING FRONT ARM
REAR SUSPENSION REMOVAL
FOX EVOL X SETUP MANUAL
Heavier Rear Springs
DRIVETRAIN
How to Change your Belt!
Reverse Actuator Repair
YAMAHA BELT SPECS
BELT,2,8JP BELT
Filling the Chain Case
DRIVE/JACK-SHAFT BEARING REPACKING
Video - How to Install BOP Oil Tank Gasket
Video - How to remove your Suspension and Service your Bearings.
Video - How to remove you lower jack-shaft and service the chain-case
ELECTRICAL
Symptoms of a bad Map Sensor
SIDEWINDER DIAGNOSTIC CODES
ECU Release Info
Quickly Remove ECU
HANDGUARD LED WIRING PICS and WRITE UP by 3UR
SIDEWINDER GUAGE UPDATE and OPERATIONAL VIDEO
Adding a Magnetic Tether to SIDEWINDER
CLUTCHING
Clutch Knockout ring install Video
Clutch Knockout ring Before install Video
Clutch Knockout ring After install Video
TY TECH ALL THE CLUTCH SPECS AND MORE
Primary and Secondary Torque Specs
General Release Info
WHO-HAD-THEIR-SECONDARY-APART
Primary Spring Specs
Latest: PRIMARY CLUTCH SPRING SPECS
TPI Big Venum
Hurricane SuperTuners
OSP Adjustable Weights
Turbo Dynamics Clutching
Ulmer Clutching Charts for Flashes and Silencers
DO NOT ROTATE CW when changing clutch parts
ENGINE/ PERFORMANCE
Adding a Catch Can to 2020
Adding a Catch Can to 2017-19
Getting rid of the roll over valve
Motor Release Info
Turbo Release Info
ECU Release Info
Misc Release Info
EVO Dyno Results
Turbo Dynamics Dyno Results
Hurricane Dyno Results
Alpha PowerSport Intake Install
Turbo Dynamics and Beerman Boost Leak Test
EXHAUST
Removing the Exhaust
Evo Silencer
OSP Silencer
Turbo Dynamics Silencer
Hurricane Silencer
Excell Silencer & Dial Boost
Ultimate Muffler-Decibel-Test by Beerman
Problems, Tech Issues and Updates
Front Exchanger Coolant Leak/Fueltank,EX shields,Batt Removal
Wont Start in Real Cold
Check your Turbo Bolts
Flat Spots on Rollers
Blowing Belts
Blowing Belts Solution
Check your Secondary Bushings
Check your Clutch and Air Intake Filter (NO OIL)
Turbo Heat Shield
Rollover Valve Problems
Common Codes
SD 25 Code
SD 26 Code
SD 43 Code (Frozen Fuel Pump Relay)
SD 84 Code
ACCESSORIES
Windshield Height Comparison
Portable Jump Packs
HOW TO VIDEOS
How to make your lower panels removable.
VIDEOS
General Release Videos
MANUALS/SPECS
Deilvery Spec Sheets
RIDE REVIEWS
Formal Release from Yamaha
First Production Ride Review by Nbsledder
500 Mile Report and Suspension Setup
MrSleds Sidewinder LTX-LE
Paint Codes
Skis
Tracks & Studding
Studding
SUSPENSION
FLOATING FRONT ARM
DRIVETRAIN
YAMAHA BELT SPECS
BELT,2,8JP BELT
ELECTRICAL
ECU Release Info
Quickly Remove ECU
CLUTCHING
TPI Big Venum
ENGINE/ PERFORMANCE
Motor Release Info
Turbo Release Info
ECU Release Info
Misc Release Info
EVO Dyno Results
EXHAUST
Evo Silencer
OSP Silencer
Hurricane Silencer
Blowing Belts
Turbo Heat Shield
Common Codes
SD 25 Code
SD 26 Code
SD 84 Code
ACCESSORIES
Portable Jump Packs
HOW TO VIDEOS
VIDEOS
MANUALS/SPECS
RIDE REVIEWS
Please let me know if there are things that we could be adding to this listing to help keep the site in order.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Please put a thread on Nord Locks and Hex head bolts for the 3 turbo bolts.
- Sauk Prairie, WI
- www.ty4stroke.com
Nice work here Tom. What a great resource
asherw
- Jan 28, 2016
- New Jersey
- 2016 viper rtx le
Great info! I want to buy the quietest 250 kit. I can't find which silencer is closest to stock. Any help for my ltx le would be appreciated!
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
Seems like a Code25 has appeared for some riders as well as a Code26. Might be worth adding Code25?Please let me know if there are things that we could be adding to this listing to help keep the site in order.
Done!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I think the "Removing exhaust" thread should be added.Please let me know if there are things that we could be adding to this listing to help keep the site in order.
Whats the link? I just want to be sure that we add the correct one.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
A must for FAQ.Whats the link? I just want to be sure that we add the correct one.
https://ty4stroke.com/threads/removing-exhaust.145783/
Thnx Tom,
Dan
It now added.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
MrSled, I think under "clutching" where it reads "Do not rotate CCW..." it should read "Always rotate CCW...", right?Please let me know if there are things that we could be adding to this listing to help keep the site in order.
It should read - Do not rotate CW or Always rotate CCW
Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
I am looking for skid torque specs mainly rear axel torque. I am installing a four wheel kit. Thanks.
As you can see they differ for no reason at all. Rear axle is something you may have to do on trail if track stretches etc. I usually just make them tight. Loctite everything.
