ATT: Speed Freaks apex/attaks for tracks
SledFreak said:
The key does not give the true timing, because of the way the key is adjusted in the fly wheel. ie. If you have a 4 degree timing key, it's probably only advanced 1-2 degrees. The ignition controller can go up to 10 degrees. Whe yo uare at 10 degres, it's a true 10 degrees. For trail ridiing, Allen has maps that run 10 degrees in the lower RPM range with more fuel and pulls it back to 4-6 degrees up top. It works very well... Once you start playing with it, you will see the affects of changing fuel and timing throughout the TPS/RPM range. Get the LCD screen and you can store over 30+ maps and load at any time. ie. lots of timing and fuel for 660ft or decrease it a bit for WOT for 2 miles.. You can also push to REV limiter past the stock, which is 11,200. You could easily push it 11,500-12,000RPM..
With this mod vrs your stock setup,minus clutching,what did you see for mph gains on top,did you ever break 120 gps or radar with your gt,some have done very well with out alot of mods,just lowered geared and clutched. Thanks Pete
