Attak / Apex add on cooler / heat exchanger... got one?
Going to dealer tomorrow to have the kit installed in my '06 studded Attak. They mentioned the (2) square tubing extrusions that support the tunnel extension have to be cut, the heat-ex gets installed then they weld / rivet or whatever the extrusions back in place. Does this sound about right? Sure would like to avoid the Frankenstein look if possible.
thanks for the info. However if don't place extrusions back I was wondering if track bottoms out would it cause damage to the extra cooler. (ie I have nonstud track ) Has anyone with this "warrior cooler" on the attak 06 have any problems because I definitely need it . My attak 06 ran hot again . I need a cooler bad!
Heres a pic of the custom rear cooler I made for my turbo Attak. the way they should have been done from the factory. It will not take up any additional tunnel clearance, so the studs will not hit no mater what. It came from a 98 Ski-Doo 440 and I cut off their inlet tubing and welded in 800 v-max elbows on to it. Very pleased in the way it turned out.
