SharkAttak
i have to change my chain to 68L instead of 70L, are the chains 3/4" hyvo chains? and on the 22T top sprocket what is the internal teeth 15 or 16, i've been looking at Team sprockets would they work and has anyone ever used them
SharkAttak
does everyone use yamaha gears and chains?
LazyBastard
Yes, 3/4 HYVO. And the top sprocket has 16 internal teeth.
BigMac
- Jun 27, 2004
- Brainerd Lakes area, Minnesota
Team sprockets are about the same price. Personally, I saw no reason to vary from OEM.SharkAttak said:does everyone use yamaha gears and chains?
Allen Ulmer sells sprockets for exactly the same price as TEAM. You might consider calling or emailing him...find out what brand he sells, and his take on OEM vs other.
SharkAttak
BigMac said:Team sprockets are about the same price. Personally, I saw no reason to vary from OEM.SharkAttak said:does everyone use yamaha gears and chains?
can you run a Team HYVO bottom sprocket with a yamaha top sprocket and chain or do you have to go one way or the other
BigMac
- Jun 27, 2004
As long as they're the same size with a Hyvo cut, I can't see why it would matter. I guess the question is not size or fitment, but the quality of the sprocket, Yamaha vs TEAM. I don't know about accuracy of machining or longevity of one brand vs the other. I opted for a Yamaha top gear simply because I have experience with Yamaha parts and have found them to be of good quality. TEAM may be just as good, maybe even better, but personally I have no experience. I've seen some guys write about the shimming being different with aftermarket gears in order to get them to line up - I went with the brand I know, and because I know the Yammie would be a drop-in.SharkAttak said:can you run a Team HYVO bottom sprocket with a yamaha top sprocket and chain or do you have to go one way or the other
SharkAttak
BigMac said:As long as they're the same size with a Hyvo cut, I can't see why it would matter. I guess the question is not size or fitment, but the quality of the sprocket, Yamaha vs TEAM. I don't know about accuracy of machining or longevity of one brand vs the other. I opted for a Yamaha top gear simply because I have experience with Yamaha parts and have found them to be of good quality. TEAM may be just as good, maybe even better, but personally I have no experience. I've seen some guys write about the shimming being different with aftermarket gears in order to get them to line up - I went with the brand I know, and because I know the Yammie would be a drop-in.SharkAttak said:can you run a Team HYVO bottom sprocket with a yamaha top sprocket and chain or do you have to go one way or the other
thanks, so what i got ot find out if Team gears are compatible with yamaha so the gears will line up, i'll have to call Team Ind. on Tuesday
BigMac
- Jun 27, 2004
SharkAttak said:thanks, so what i got ot find out if Team gears are compatible with yamaha so the gears will line up, i'll have to call Team Ind. on Tuesday
http://www.ty4stroke.com/viewtopic.php? ... m+sprocket
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The Team top gears will interchange just fine, but the bottom sprokets that Team offers are for non-reverse models only.
SharkAttak
Srxspec said:The Team top gears will interchange just fine, but the bottom sprokets that Team offers are for non-reverse models only.
thanks Allen, i'll be calling next week to order a 40T fo an Attak
