Attak Studding question??
108 studs and my Attaks track never ratcheted. Same amount in my Warrior and it did until I tightened it.
MrSled said:
hmm, I will have to check the drivers...thanks
If you change to anti-rachet drivers you must have changed track??
yea I went to a 1.5" ripsaw pace 3 design. I'm not saying with this was the problem 100%. I just find the wear marks very interesting and I assume this could have been my problem. If I can ever find my digital camera I will take a couple of pictures of the wear marks wear I think the track was climbing. On a side note- If I would have noticed these marks before I bought the anti-ratchets I probably would have measured everything up and adjusted the drivers how I thought they needed to be and tried it again. but I had the anti-ratchets in my hand and did the install. Good luck Tom. ;)!
Mighty, did you ever try running them on the grass and what did you have your track tension set too??
Sorry it took so long but here are the photo's. I also believe by looking at them again it was the clutch side drivers not the chaincase side as I earlier posted.
I set the drive shaft up on 1-2-3 blocks on a set-up table with a heighth gage and measured everything that I could. I also reinstalled the drive shaft with out the track just to scribe some lines for reference. Plus I took measurements of the track, like center to center of the windows and so on. I can't remember what the actual #'s where but I know that they didn't add up correctly on the factory drivers. Even though My lighting might not show it these marks go all the way around the driver. Leads Me to believe the track was climbing on these 2 drivers.
