attak studding w/rear exch
bluduc
Any issues w/studs hitting factory rear heat exch. nobody seems to make protectors.
They hit even with protectors if your using accessory exchanger. look under a 06 Rage! The exchanger should mount on top of the tunnel. That is the only way they won't hit. I made one last year out of a Ski-Doo exchanger and mounted it that way. Do a search, you will see the pics. Under the tunnel and it takes up travel from the suspension.
