RTK
I ran 108 all down the middle, 1.40 extreme max studs. Works better then my 03 rx-1 with 192 woodys. The ripsaw is one hella track to start with.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
on my rtx I ran 144 x 1.375 mack studs with the mack spacer/support washers and all woodys double backers all in a v pattern up the center. I didn't use any singles i think the doubles are a little stronger and nasty looking. It looks kind of similar to what monsterattack has for a set up. I had to make my own pattern because nobody had a pattern for 144 up the middle with all double backers on a short track
My sled is on the lift as we speak and all studs look like new except 1 stud that the carbide came out of.
not a single bent stud.
I have had good results with the mack products and would highly recomend them.
the v pattern works well for me. i dont like studs on the outside edge of the track.
Obviously my sled is a short track and you would need more studs to pull off the same pattern on your sled. Just wanted to offer a little info on the mack studs and studding in a v pattern up the middle.
