attak upper idler wheels
raginyamaha
Waterford, wi
2013 xtx
Trying to replace the upper idler wheels on the attak. do they need to be pressed off or am i missing something, snap ring perhaps?
upper idler wheels
Get yourself a diposable bolt of the same size that you took off and hit it with a hammer while holding the wheel. It will come off. Repeat on the other side. Bearings are replaceable get good ntn ones.
remove the circlip and tap the wheel off from the bearing. Put the bolt back in the end of the shaft and use a puller to remove the bearing. This is the best way as beating on the shaft will ony damage the end.
