Attak won't start
Heritage
Northern Wisconsin
Attak won't start....had it running this morning..shut her off, and went in for an hour....now wont start....cant hear fuel pump.......starter relay?? It is cold 2 below right now...if it is relay where is it located..and what do I do?
Fuel pump relay. There are 4 relays located just above your left foot. You have to remove the side panel for access.
The fuel pump relay is the one with the red wires running to it. Remove it, warm it up in your hands and plug it back in. Then you should be good to go.
