bagadonitz
Yes please post pictures for the win!
DARTING GONE
THANKS FOR EVERYONES HELP WITH THIS. I PUT A 3/8 SHIM ON THE REVERSED RUBBER , WORKS GREAT !!!!! 99.9% OF THE DARTING IS GONE. I PUT A 145 MILES ON MY SLED TODAY AND I CAN SAY FOR SURE , THAT THIS IS THE MOST FUN THAT I'VE EVER HAD ON A SNOWMOBILE !!!! THANKS FOR ALL YOUR HELP.
Snoxracer242
Which way is the rubber supposed to be and which way our you turning it? If I look at the rubber under the spindle, the groved side is to the front. When you are shiming the rubber you are trying to force the front of the ski up? Correct?
IT SEEMS LIKE OUR SLEDS WHERE SET UP DIFFERENT. MY DEALER PUT THE GROVED SIDE FACING THE REAR, THIS MADE FOR FAR TO MUCH PRESSURE ON THE SKI TIPS. SWITCHED THE RUBBER AROUND, PUT A 3/8 SHIM AND IT MADE ALL THE DIFFERANCE IN THE WORLD.Snoxracer242 said:Which way is the rubber supposed to be and which way our you turning it? If I look at the rubber under the spindle, the groved side is to the front. When you are shiming the rubber you are trying to force the front of the ski up? Correct?
Snoxracer242
Mine came the way everybody has switched them to, but to me that looks like the way they should be anyway. (groved side forward)
Dustin
Dustin
racingronnie
Original ski's, shimmed, turned rubber around. Final fix for me was Woodys Doolys. Sled is fun to ride all the time now.
srxtim26076
- Dec 12, 2007
i did the same thing and my darting is completely gone. First I tried one dually which helped considerably but two fixed my problem.
- 147K
