Or consider getting a good sized riser like Pimpedrsrage has. That riser makes the sled look easy to ride on bumpy days. But you will need to extend those cables.
2 inch. Otherwise you need longer cables. You can reroute one or two. Throttle cable just buy the mountain cables. You'll be fine then and they aren't that expensive.
