yamrx1
How high of a riser can i go with before having to change cables and brake line on my 04 rx1 mtn..Thanks.....
Cnaser
I just put on a 3 inch bar riser and I had to put on a new cable. If you go that route you should order a throttle cable for a 2005 mountain rx1 it will work perfect. and it should cost about $22.00 depending on your dealer
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
Yea, anything longer than 1" you will need a throttle cable. Then you can go to about 3-1/2" before having to change the other cables and such.
J.
J.
yamrx1
2" riser and a throttle cable of an 05 mtn will do the trick will it???
Jonny Rocket
yamrx1 said:2" riser and a throttle cable of an 05 mtn will do the trick will it???
Yep.
yamrx1
