Teamyammie3
- Oct 17, 2014
- 2010 Nytro RTX SE
Hi there I was looking at getting the barker exhaust set up and wanted people's opinions on them? Is the power noticeable? Is sound Annoying? And most of all do I have to run a fuel programmer with it?? I don't really want to if I don't have to cause I don't have the money right now unless it makes a big big difference or is going to hurt the sled
shadow44
Pretty expensive for false gains, plus it's stupid loud at 103 dbs. Find a better slip on for less money....they all make 2-4 hp, just pick the one you like best.
Teamyammie3
- Oct 17, 2014
- 2010 Nytro RTX SE
Do I need to run a fuel programmer with it or is it fine just put on?
if its just a slip on then you don't really need it. I got it mainly for the sound and weight savings, any extra power, if any, is a bonus
Cherry08
With the fuel controller should you not see a realistic 2-4 hp gain? Does anyone know what header you could run with this exhaust?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You can run pretty well any header that will accept a stock muffler, but most recommend not mixing performance products.
