Hey anyone have this on there Nytro??? I'm thinking of gettting one. 12hp gain and 12lbs lighter !!
shadow44
You may want to do a search....I can garauntee to aren't getting anywhere near those gains off of a slip on.
Ya thanks for the advice, did a search and not much info on the Barker.shaddow44 said:You may want to do a search....I can garauntee to aren't getting anywhere near those gains off of a slip on.
Just a FYI
http://www.youtube.com/watch?v=gKWnPv5qAt0
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
It's fairly well known that this slip on will only produce those type of numbers if installed with other mods like an intake kit and fuel controller. Don't be duped, most of us know there are hidden ponies in our Nytro's.shaddow44 said:You may want to do a search....I can garauntee to aren't getting anywhere near those gains off of a slip on.
shadow44
Here's a read from a few years ago about some dyno results and a Barker. There's is very little dyno info on this muffler, regardless it will not make anywhere near 12hp even with an intake mod and fuel controller. Any quality slipon willl make 3-4hp at best..add filters and fuel and you may get 8hp. To make 12hp gains you need a full exhaust, intake mod and fuel..pretty much fact with tons of dyno support.
http://www.ty4stroke.com/viewtopic.php? ... rkers+dyno
09NytroRTX
my buddy has a slip on barker and my sled was stock at the time.. there was no difference in the sled so the 12 hp gain is bogus.
I didn't think I was going to get 12hp gain, if I get a few hp and shave 12lbs and sounds sweet I'm happy. I did get the silencer also.
shadow44
sharky007 said:I didn't think I was going to get 12hp gain, if I get a few hp and shave 12lbs and sounds sweet I'm happy. I did get the silencer also.
Good luck getting buy a stop check in Ontario unnoticed....94db with a noise reducer on the Barker. Snowtrax TV installed one on a Nytro a few years ago. They claimed they never trail rode it but I saw them unload in Pembroke one day...I could here that sled Idleing across a busy highway.
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
Barker and Schmidt Bros. both used my sled to design their exhaust. Barkers is smaller and lighter with a deeper rumble. Schmidt Bros. is dual exit with a higher pitch more like an Indy Car, heavier built with more quality. I have 4 years and 14,000 miles on Schmidt Bros. and it is still in excellent shape. We put the Barker on my buddies sled and the only problem we did have was blowing the packing out. I believe do Schmidt Bros. are closer on HP numbers.
jonnyz36
I have the Barkers Exhaust. I wouldn't say the HP gain is anything to write home about but the weight loss was noticable. Not to mention it sounds awesome. I don't have to worry about DB levels where I live so I could care less if its loud.
HRD2PLZ
I run the Barker with an EHS Bullet Box. 12 hp, no. Is there a gain, yes. It's quality workmanship, fit well. It's loud, but has a nice sound. Reducer helps but also decreases performance. I have had to repack it, but its easy.
HRD2PLZ said:I run the Barker with an EHS Bullet Box. 12 hp, no. Is there a gain, yes. It's quality workmanship, fit well. It's loud, but has a nice sound. Reducer helps but also decreases performance. I have had to repack it, but its easy.
How often do you have to repack?
HRD2PLZ
I didn't have to, I just did. Seemed like it was getting louder. But anyway, once in 3 seasons. I don't run the reducer either, tried it but didn't like it.
