biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I did note the the JB weld High Heat is in that range. The JB weld Extreme heat is rated higher. And they mostly talk about exhaust systems for their purpose. Who knows.Permatex® Muffler & Tailpipe Sealer - Permatex
www.permatex.com
It is kaolin based which is a silica based clay material. Similar to JB Weld exhaust products. No experience using it but I have seen very little that is rated above that 700f rating.
earthling
That permatex sealer @ 2000f is the highest I have seen next to some of the fireplace sealants (2500f). The JB Weld High Heat is water soluble, the other kaolin based JB Weld products are not but rated to less heat.
viperaddict
- Sep 6, 2004
- Alton NH
- 2003 viper w/monoshock and simmons skis
2011 apex SE
I've used red rtv to seal up 2 stroke exhaust between the pipe and can, would this not work in this application?
earthling
It just depends on how hot that particular section gets. All of the silicons give up around 6-700f and repeated exposure.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
Permatex Optimum Red is supposed to handle 750-degrees F but intermittently.It just depends on how hot that particular section gets. All of the silicons give up around 6-700f and repeated exposure.
earthling
ok, corrected to 600-750f, but it still all depends on just how hot the exhaust gets at that position. If the exhaust is only 500 may be okay, but if its hotter, don't bother.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 RS Vector
2006 Apex GT
- Middleville, MI
It definitely will be hotter that close to the heads. I bet it tops 1100/1200-degrees F when run hard.ok, corrected to 600-750f, but it still all depends on just how hot the exhaust gets at that position. If the exhaust is only 500 may be okay, but if its hotter, don't bother.
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
NLP_SLED_GUY
- Sep 14, 2021
- Northern Lower Michigan
- 2019 SkiDoo GT-L 600R
2005 RS Rage
2003 RX1
1980 Arctic Cat Panther
I tried to use this JB Weld stuff for a minor repair at the header/muffler coupling on an 05 Rage. It didn't survive the first ride.
I think I found something rated higher but never used it. It's really just better to properly repair or replace.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Just thought I would update on these. I have opted to go with stainless rivets to secure the flange to the pipe. The titanium drills much easier than i expected. Once the flange is in place, one just has to drill the through holes. 3 on top and 3 on bottom like i show in the photo. Using a sealing blind rivet so they should seal internally to prevent any leaks. Beings the flange installs inside the pipe and the expansion rate of the collar is more than the pipe there should be minimal leaks if any. Even if there is a little leak it is sure to be much less than broken flanges! Hoping to get them added to the website later today.
