petetown
- Jan 6, 2012
- Melville,SK
- 2011 nytro xtx boooooosted!!!
I have a set of supertips in my turbo nytro running 10lbs boost they are 50 base trying to figure out how adding / subtracting weight in each position effects performance ex. Heel vs tip anyone care to simplify this for me? Anyone have a good base setting to work off of for these weights ? I run at 1500ft currently a tungsten and 4 steel in heel and I believe 3 in middle as well as tip it is an xtx I am running a 2.25 camo extreme I have a 45 helix which seems ok I see a lot of ppl use the 47 which I have not sure what I should try anymore!?
