Vectorboost
- Jan 16, 2014
- Saratoga, Minnesota
- 06 vector mcx turbo
Have a 2010 mtx 162 with push turbo 6 ibs boost. track is cut down to a 1.75.. .. Rode ditches yesterday very loose snow couldnt build the boost like on the trails and clutches got a bit hot.. running supper tip weights 50y base OPO primary spring, Tungsten & 2 washers in heel, 2
washers mid, and 4 washers tip.running a 45 helix dont know what its set at for degrees will check tonight. should i add more weight to help with heat adjust helix? Seams to run a little high on rpms at wot on hard pack also..over 9100..
Vectorboost
- Jan 16, 2014
forgot to mention sled has been geared up from 18tooth top to a 22 tooth top
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Your belt is slipping in the secondary under heavier load of ditch riding compared to trail, creating the heat, and the taller gearing doesn't help the situation any.
That is a factor of the 45 helix angle... You tune the primary to control RPM, not the belt heat or slippage...
Vectorboost
- Jan 16, 2014
what would you recomend for a helix
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Will send you a PM
