poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Hey everyone been having a little more then usual trouble with belts on my nytro this winter. Used to get 2,000 Kms on a belt without much trouble. Now on this last one I'm down to 1100 Kms. Went through two this winter. Other one had about 1600 Kms on it. (Had been installed the previous winter)
When the first one went this winter I went through and did some checking. I set the clutch offset to about 15.8mm. I also put new Ramps in on the secondary and a new spring. Bushings were good yet.
When I took the belt off yesterday I noticed the fixed sheave on the primary was hotter then the rest. It's also always the inside of the belt that the cords start to separate on. I've never actually had a belt blow up but the cords always start to come out.
Conditions have been heavy going the last month now as we've had a lot of powder snow. Most of my riding is off trail. Sled is completely stock except for the 1.75" backcountry track. I know I should drop down a couple teeth on the gears but haven't done that yet. I'm sure that would help some with belt life.
Any advice on what to look for and check is appreciated.
Thanks.
Thanks.
