darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Yes they will do your clutches
brada
charlie said:Ya everything is ok I am thinking Machining is the way to go who does it?
http://www.ty4stroke.com/viewtopic.php? ... =overdrive
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
Ulmer racing will machine your clutches
they did a couple of mine, great job , fast turnaround
charlie
Thanks airwolf thats what I wanted to the t that helps a lot now I wonder who would be better I am very Happy with Allan's work. Schmidt bros did the clutching on my nytro and was vary happy with it to
Every once that I know that machine there clutches on bare ice in a 1/2 mile on apex's with the ripsaw and trails studs run 120-124mph on the gun.Thats at stock ride height.
charlie
I would be happy with 115 to 118 I just want to beat my friends etec but it will never end
gun nut
belt
I bought an adjuster in 06. It fits on the secondary bolt. You use an allan wrench to allow you to turn the adjuster by hand, and tighten allen screw.
charlie
what does the adjuster do i dont really understand
I think gun nut is talking about belt deflection adjuster on the secondary....instead of shim/washers behind the 3 bolts........................different topic.
