Belt slips?
mx1500
meath park, sk, canada
not sure if its normal for the nytro. last year i took some silicone and sealed every darn crack on the clutch side of the belt so snow had no wheree to come in from. now this year and a part of last when ever i do a hard landing the belt slips? the belts good. anyone else have this problem. ill be honest im not the easiest on my baby. i know that snow causes the belt to slip but when i pul it in the shop, theres NO snow on the clitch side.
Most likely your secondary isn't backshifting quick enough. So you jump, land, and back on the gas while the belt is still low in the secondary clutch causing the slip. You can try tightening the secondary spring for quicker backshifting just watch your RPMs, they will go up when you tighten it. Other wise maybe a different helix might help.
