If its squeeling, the secondary sheaves are too tight. You'll need to adjust the sheave spacing by removing washers on the three bolts on the back of the secondary that control how wide the opening is before shifting occurs. The belt should be flush or up to an 1/8 in higher then the top of he secondary. If you check, I bet the belt is more like 1/4 in higher. That's your problem.
