rsrage06
- Mar 22, 2007
I am having problems with my drive belt squealing at idle and on the throttle doesnt matter if its a new or used belt. Does it all the time and its more anoying than anything. Any help would be appreciated. Thanks
sparks49
I'm guessing you need to adjust your clutch, I'm no expert in this matter to say the least, however I was having a similar problem and got referred to this page:rsrage06 said:I am having problems with my drive belt squealing at idle and on the throttle doesnt matter if its a new or used belt. Does it all the time and its more anoying than anything. Any help would be appreciated. Thanks
http://www.ty4stroke.com/viewtopic.php? ... hlight=101
It's a detailed description of adjusting your clutches for belt deflection, should help, good luck.
