Bender Helix Angle in 2003 RX-1 ?
Jack_Shaft
N53.486 W59.860
Of course, Bender won't tell you unless you play coy and yada yada.....
No time for that.
Does anybody know what degree this helix is? I bought the kit that included the Heel Clickers in the primary clutch and I would like to compare some notes in order to tune around this secondary set-up.
If anybody knows what it is, please post up.
-JS
How are the heeclcickers loaded? I can work backwards & take a close guess by the way the weights are loaded.
Turk: I'm probably running the same clutch as Jack_Shaft.
Stage 2 turbo 5-6 lbs of boost. Heeler clickers 5.7 in heel, 5.6 in first hole, 3.7 in tip.
White heel clicker primary spring, White Bender secondary spring that is not a Yamaha spring. Secondary spring set at 30 degrees. It is very tight
at 30.
Helix marked 03 RX1. I'm 220 with gear. 192 woody's 1.325 studs. Sled pulls right to 9800 RPM and stays there. I was wrestling with the jetting and a bad boost guage for the little amount of time I got to ride this season so I never touched the clutches. Never got a chance to really try high boost to see where it would shift out.
