Bender stage 2
Skydog
Byron, IL
Any info i should know on set up? Or the install? What kind of boost can i run on good pump gas?
Thank you Skydog ;)!
What kind of jetting should i run? AT 800 feet? Do you guys run the stock springs in the carbs?
THank you
Bender told me to run stock jetting, but thats not working very well
My first ride I had problems with the boots from the carbs and the inner cooler blowing or moving off. I had read about this problem before I rode and tried to glue them to the carbs but didn't work. I went to the NAPA store after the first day and got a 8inch chunk of 2 1/4 fuel filler hose to replace the shorter boots. Cut them to length so that they couldn't move in either direction, no problems since. If the boots look short, don't even put them on, make longer ones. My .02
viperbusa, can you get a pic? You mean the boots after the carbs where the inner cooler goes on?
I bought a used kit.
Thank you
