bender stage2 lean problems
440dart
C-falls MONTANA
my sled is lean at full throttle runs real strong at mid throttle but at full throttle it starts popping how do i richen it up do i put biger main jets or charge tube jet
You should get pretty close with the main jets and use the pitot jets for fine tuning. If you post what you are currently running I am sure there will be plently of folks that can help you get where you need to be.
J.
J.
What he said.
spray25 said:
J.
What he said.
What they said.
cant get close to the rev limiter for it to bounce off i cant tell what jet is in the charge tube it got scratched off but the top is a 720 it looks bigger and it runs worse then the jet thats in it
700 to big. try a 200 or braze 1 shut. the higher the # the leaner you are
700 is normally to big, but without knowing your jetting and elevation it is all a complete guess.
Ted, is right 95% of issues with boosted RX-1's are leaking tees. Do yourself a favor and ditch the plastic ones and get aluminum ones. MPI sells them.
