Dano - just run a strip of nylon or anything around your rear bumber down to the bottom of your flap and attach it - that will keep your flap from going under the sled when reversing.
Mach1Mike
Glad they took care of it.There is a demo Attak on ebay right now with a tweeked tunnel.starting bid $5995.00 1400 miles.
b4xc800nowapex
- Mar 15, 2005
I am positive that I did not run over my snow flap. My track is not studded. I do experience execessive bottoming of the rear suspension. I am 130 pounds. The dealer has installed the big boy spring for my light weight body. I am the only rider of this sled so I know exactly what this sled has been through.
Alatalo
- Jan 11, 2005
The seat is supported by the tunnel but also by the silencer heat shield.LazyBastard said:Actually, the seat is NOT sitting on top of the silencer, its sitting on the TUNNEL, up forward of the rear mounting point. The part above the silencer is just cosmetic and doesn't support any load, except to keep the seat from falling off.Alatalo said:The seat is sitting on top of the silencer heat shield.
The silencer heat shield is bolted to the back of the silencer.
The silencer is bolted to the tunnel.
If you bottom the suspension out when sitting on the seat, part of the force from your body weight will go down through the seat, through the silencer heat shield, through the silencer to the very rear part of the tunnel. How much force is decided by your body weight and by how far back you are sitting when bottoming out. Enough force and the tunnel will bend downwards.
Both me and my mate bent our -05s only couple of seconds apart when we were caught by a deep hole right in the middle of an otherwise flat high-speed part of the trail. Also, we were non-studded and our snowflaps looked perfectly OK after this...
Alatalo
- Jan 11, 2005
Also the weight of the silencer contributes to this "bending problem".
However, I believe the force from part of the body weight is the main reason (I am 100kg, the stock silencer is 8 kg...).
