Bergstroms triple points on C&A's
ski
i have several sets of skis, but for trail riding stock ski with ski saver and
six" triple points they are very good, make sure on alignment.
I ran them on my 06 Attak with stock skis and with Slydogs.
Darting was reduced under most trail conditions. Still darted when you ride on a freshly groomed trails.. but everything does.
They still pushed like a MOFO with either ski.
Overall I wasn't impressed with them but you may ride differently than I do.
They did not help turning on ice or in like a gas station at all. Still have to get off the sled and pull the front end around, or just take the long/wide turns and hope ya got it pointed in the right direction.
My Attak is studded, dropped the front end, sucked up the limiter strap and reduced the transfer. I've tried every suggestion on here to get that tank to corner. Horrible handling sled for my riding style... I'm 3 levels beyond "aggressive".. more like "a$$hole" style.
My triple points need to be replaced.. they lasted about 1200 miles.. which I guess is OK. Center carbide is flat, outer 2 on each side have rounded edges.
I have a set of C&A Pro's but never tried those skis on the Attak as they didn't work all that great on my SRX.
Would I buy them again? No.
Now they did work OK on the GT's I ride with.. but not as good as a set of CB Performance that one of the GT's had for awhile. Those stayed sharp for well over 1000 miles. He lost a chunk of carbide so he put on the Bergstrums.
