Best battery for Apex
Jona$
Master
Northern
Sweden
Tapex/sks 800 -16
I need a new battery and was wondering what is thé best one to get :Rockon: the Original battery has let me down one to many. I want the extreme and reliable! :sled1:
Yuasa YTX20H-BS batteri and CTEK MXS5.0 as charger is what i ended up with :)
Good choice. Last year I put in the Interstate brand YTX20H-BS which fits perfectly with the original foam spacers removed. This battery has 310 CCA compared to the original battery which has 200 CCA. It is a few more pounds but the extra CCA is worth it IMO.
The Interstate brand YTX20H-BS that I installed is a AGM battery. I am assuming that the Yuasa YTX20H-BS is also a AGM battery.
That is a good deal! Just make sure you do not order the YTX20HL-BS. The L has reversed polarity.
victorn said:
Will Yuasa YUAM62RBH YTX20H-BS Battery fit 03 rx1?
Thanks!
Welcome to TY! Please add your location to your profile.
I believe that the RX-1 did use the larger 20 series battery. Perhaps someone else more familiar with the '03 RX1 can confirm.
