HABS 1
- Oct 22, 2015
- corunna,ontario
ok thanks again! so ill just contact vv mapping and they should have card with what i want installed on it correct, just buy it and good to go?
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
You will buy the subscription to VV mapping and download their product. There is two programs/ways to install it on your GPS. Either you use the install to SD card (SD card installed in the computer) or you use the program that connects to the GPS which allows you to install VV Mapping to internal memory or the SD card installed in the GPS.
HABS 1
- Oct 22, 2015
- corunna,ontario
ok awsome , thanks alot , really made this easier!!
HABS 1
- Oct 22, 2015
- corunna,ontario
HABS 1
- Oct 22, 2015
- corunna,ontario
HABS 1
- Oct 22, 2015
- corunna,ontario
this is where it will sit i have a flat suction cup plate installed in front of gages for go pro i can. use but my gps mount to short need anoter 2 inches, looking for mount now, should work good if it dont freeze, my windshield dont cover it all! and will be to low if i tuck be hind windshield!! thanks again
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
There are some maps for ontario over at Ontario Conditions forum but I do not know if they are routable or will work in the Nuvi due to the routing aspect. I believe they are free.
HABS 1
- Oct 22, 2015
- corunna,ontario
ok thanks ill check it out! got a new higher mount and a waterproofcase and waiting on vvmapping sd card from jermy worked out nice all for about 100 bucks thanks a lot gyes,just a note jermy at vvmapping very nice to deal with and helpful!wish he had the Ontario maps
yamarider13
- Mar 9, 2014
- East Central Wi
- 2014 Vector LTX
2015 Venture GT
http://www.trailsystems.com/ This is a good place to get a bracket to hold your GPS above your gauges also. Works good on my 2014 Vector to hold my Nuvi 55.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Not routable, but will work on the Nuvi.
