Best ski for nytro
bluegrass
What is the best ski set up for a nytro xtx. is the tunner ski as good as it get"s is there some thing better. I put a set of runners on my -2 nytro xtx I don't think I got it dialed in because it steers hard and darts like carry I am running woodsy 4 and 2 on one of my sled and 4av4 on the other I was hopping this would solve the problem but it has not what should I do next can you make a nytro run with zero dart if so what do I need to do it
i like curves with a shapper bar, works great for me
Hard to beat Curves on a Nytro! I'm not a big fan of the dual keel skis.
skis
Ive tried C&A razors and Ski doo pilots The pilots are a lot better I would like to try the 6.9 pilots.
I'm running split rail ski's on my XTX with dual 6" carbides and like them real well.
Had curve and split rails.... If your doing any off trail curves for sure. Trail riding slight edge to split rails. Still great skis by both.
X2 i have curve skis and they are good in ALL conditions....
Anything other than the stock skis is a better choice!
I run the 6.9 pilots with a 6" shapper bar in the middle and 4" on the outside....works really well...heard good things about the curve skis
Exactly the same on mine. Works excellent. Floats so much better. Although I have minimal push in loose snow.
ski's
can't wait to to try my powderhounds tonight, hopefully I can see an improvement, I will post later
:die stock
