bluegrass
- Mar 6, 2007
What is the best ski set up for a nytro xtx. is the tunner ski as good as it get"s is there some thing better. I put a set of runners on my -2 nytro xtx I don't think I got it dialed in because it steers hard and darts like carry I am running woodsy 4 and 2 on one of my sled and 4av4 on the other I was hopping this would solve the problem but it has not what should I do next can you make a nytro run with zero dart if so what do I need to do it
LM7800
- Dec 4, 2011
- ohio
- 2016 viper ltx LE sold
i like curves with a shapper bar, works great for me
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Hard to beat Curves on a Nytro! I'm not a big fan of the dual keel skis.
skis
Ive tried C&A razors and Ski doo pilots The pilots are a lot better I would like to try the 6.9 pilots.
I'm running split rail ski's on my XTX with dual 6" carbides and like them real well.
09NytroRTX
Had curve and split rails.... If your doing any off trail curves for sure. Trail riding slight edge to split rails. Still great skis by both.
09nytro
Man...SLP Powder Pros are hard to beat on a nytro
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
X2 i have curve skis and they are good in ALL conditions....09NytroRTX said:Had curve and split rails.... If your doing any off trail curves for sure. Trail riding slight edge to split rails. Still great skis by both.
swmichvector
- Jan 27, 2009
- Clare, Michigan
- 2011 NYTRO
Tuner skis. Nuff said!!
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Anything other than the stock skis is a better choice!
Tyloooor
I run the 6.9 pilots with a 6" shapper bar in the middle and 4" on the outside....works really well...heard good things about the curve skis
older mxt ski or c&a adx
yamariv
swmichvector said:Tuner skis. Nuff said!!
Tuner x2!!
newfie09xtx
- Jul 13, 2011
- Corner Brook, NL
- 2016 Polaris Switchback 800 Pro S
Tyloooor said:I run the 6.9 pilots with a 6" shapper bar in the middle and 4" on the outside....works really well...heard good things about the curve skis
Exactly the same on mine. Works excellent. Floats so much better. Although I have minimal push in loose snow.
Ffbsy
ski's
can't wait to to try my powderhounds tonight, hopefully I can see an improvement, I will post later
stock
stockSimilar threads
