Best way to lift engine out?
kinger
Clear Lake, IA
Website
www.piergenius.com
Is there any hoses or anything under the engine I should not wrap a strap around to help lift? Were going to lift it then tighten a ratchet strap to the overhead boom, then lift again, etc. I still can't see whats under there looks like a coolant and oil hose. Thanks! :rocks:
yes coolant lines, when you reinstall becareful not to crush the water pump as that hapened to a friend of mine on his 2003 rx1 & had to pull the motor again. :rocks:
I had one strap under exhaust. Front end i used holes above motor mounts
