Big boy 18’ ltx le settings please
Ndoggct
Ct
Looking for 18 sidewinder
hello i am looking for ideal starting point for my new 18 ltx le suspension
I am 6’4 250 lbs
I am going to be installing pilot skis
Any info appreciated
Thank you
I am 6’4 250 lbs
Thank you
Trail set up? or ride like an animal in the whoops.
I would say slightly aggressive trail rider
Thx
Settings for Sidewinder LTX LE:
Front suspension:
springs all the way loose… just tight enough to contain the spring in place with ski’s off the ground
Compression dampening= 1
Rebound dampening= turn left until it stops, then 8 clicks right (15 clicks is center)
Center/rear spring;
tighten spring until 3/4” of threads show between retainer nut and top of shock
Compression dampening=1
no rebound on center shock
Rear Shock:
torsion spring = 2
Compression dampening = 1
Coupler blocks removed.
Front suspension:
Center/rear spring;
Rear Shock:
torsion spring = 2
Front suspension:
Center/rear spring;
Rear Shock:
torsion spring = 2
Is there possiblility of damaging anything with coupler blocks removed? Do t the torsion springs set in them? Thx
Front suspension:
Center/rear spring;
Rear Shock:
torsion spring = 2
When u say no rebound on center shock does that mean turn left all the way till it stops then leave at that?
There isn't a rebound adjuster on the center shock.
Ok that makes sense then
I Honestly haven’t even stuck my head underneath the sled since I got it
Hoping on getting the pilots on and do some suspension tweaks Tomm
I have run the blocks removed for 8000 miles on my viper and it put a small line in it after many miles.
The coupler blocks are on a shaft that goes from rail to rail just in front of the rear axle/trihub. It controls the transfer in the suspension. If you remove the plastic blocks and reinstall the shaft and align the flat side with the flat pads on the scissor arm it gives you a bit more transfer. To do it properly you need to put the shaft in loose, fully compress suspension to hold the flats parallel and tighten the bolts
Thanks Bud. Sorry I didnt clarify.
Front suspension:
Center/rear spring;
Rear Shock:
torsion spring = 2
Interesting, exact same setup found by fine tuning a little at a time. Handles great. No power steering needed.
