Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Yes I needed a bigger spring, it was chewing up my shock pretty bad with it that tight and wasn’t acting like I think it should (hard to explain)So
basically the total opposite way as stock setting with spring? Sorry this is all new to me
Ndoggct
- Aug 25, 2018
- Ct
- Looking for 18 sidewinder
Sorry rtbo stated his center spring was maxed out, that’s my question I have is maxing it out squeezing the spring closer together?Maxed out? you need to be more clear, are you talking springs?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
YesSorry rtbo stayed his center spring was maxed out, that’s my question I am heading that is squeezing the spring closer together?
Ndoggct
- Aug 25, 2018
- Ct
I’m thinking I will end up just have to take somewhere to help me set this up
Thank you guys for your help
Ndoggct
- Aug 25, 2018
- Ct
So basically the rear rebound damper isn’t the hand knob like the fronts then?
the 3 positions is compression not rebound.
Ndoggct
- Aug 25, 2018
- Ct
Yes I was ? That rebound damper that I. Oils to find for the rearthe 3 positions is compression not rebound.
On the front I was able to click by hand that was toward bottom of shock
I can’t find these on the rears at all
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
No it does not have the small red knob like the fronts, it’s on the top near the track on the eyelet of the shock, small hex head with a notch( adjust it with a dime, not room for a screwdriver)Yes I was ? That rebound damper that I. Oils to find for the rear
And the center does not have rebound.. might be best to have him take it to someone that knows. Im done helping.
Ndoggct
- Aug 25, 2018
- Ct
When you say torsion spring on 2 for rear what exactly does that mean? There is only a clicker for compression and the top damper adjuster that I can see?Settings for Sidewinder LTX LE:
Front suspension:
springs all the way loose… just tight enough to contain the spring in place with ski’s off the ground
Compression dampening= 1
Rebound dampening= turn left until it stops, then 8 clicks right (15 clicks is center)
Center/rear spring;
tighten spring until 3/4” of threads show between retainer nut and top of shock
Compression dampening=1
no rebound on center shock
Rear Shock:
torsion spring = 2
Compression dampening = 1
Coupler blocks removed.
Ok yes I won’t ask any more questions
Thank you for your time
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
It’s the plastic adjuster to change your rear spring pressureWhen you say torsion spring on 2 for rear what exactly does that mean? There is only a clicker for compression and the top damper adjuster that I can see?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Read your owners manual?
Ndoggct
- Aug 25, 2018
- Ct
Ok thanks guys for all your helpIt’s the plastic adjuster to change your rear spring pressure
Ndoggct
- Aug 25, 2018
- Ct
No I’m sorry I don’t have oneRead your owners manual?
I greatly appreciate the help from these guys today
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I believe you can download the owners manual off of Yamaha snowmobile website.
