gmfamily2008
did you put the right twist on the secondary spring ?
Matt_phazer_rtx
- Dec 10, 2009
- Riverview, Ontario
- 2009 phazer rtx- 1.75 b/c 7" sly dogs
2008 nytro rtx 40th- studded barker pipe
I just looked at it and made sure when I took it apart that I put back in the same way as it went in (common sense I think)you started the post by saying you were clueless in clutching. If that is the case, how did you know that the secondary spring needs to be in certain holes?
Matt_phazer_rtx
- Dec 10, 2009
Ended up taking it in and got it back last friday, it ended up being a broken secondary spring (27$ part)
it must've been a tiny crack in spring b/c I looked at that spring 3 times and it seemed fine. ordered a spare spring to throw in backpack jus in case it happens again.. thanks for the help.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
If you bought a new spare that means you'll never need it. lol
