JohnGalt
- Feb 25, 2005
What does this error code mean? I couldn't find any indication as to what the error codes mean in the manual and a search on here and I couldn't find this error listed.
Any help would be greatly appreciated! It just came on and I want to be ready for the 2 days of snow we're likely going to have
flyin-lowe
What light is blinking and what sled do you have. Im sure you know there will be an on off flash until the sled warms up after it is started. It might go on for a few minutes depending on how cold it is.
JohnGalt
- Feb 25, 2005
The check engine light and the warning light at the top above the gauge.
RX-1 2003
Yes, I'm used to the normal lights flashing, but this is constant after it's warmed up and all of the other lights go off. (it starts right after that)
RX-1 2003
Len Todd
Does it have > 1/4 tank fuel? When it gets low these lights start blinking. If you hav a lot of fuel, have you checked the oil and coolant levels?
Click here for an Operator Manaul if you need one.
JohnGalt
- Feb 25, 2005
Yes, there is > 1/4 of a tank (it's actually full) and the gauge reads correctly, so it isn't that unless there is something seriously screwy with the gauge.
The Operator's manual (which I have) doesn't tell you what the codes mean, it only outlines what they are.
mmmkokanee
handwarmer probs?...disconect under the steering pad and and plug the harness ends into each other and then start sled to see if the code still comes on. If not, its a bad warmer. Try with one warmer plugged in and plugged into the harness, then the other to get the code so you know which one's bad.
