Blinking warning light
vader2185
Me
I just changed my donuts, put in cr10ek plugs and installed a new yamaheater unit. When I fired everything up it ran and sounded fine. The yellow warning light was blinking with a fuel symbol and that was blinking as well. I am thinking I forgot to hook up a connenctor on the gas tank. Hopefully it is not something more seriuos. The wife says it is only Sept and she is a snowmobile widow so any insight into this issue that would save me some time would be appreciated.
Sounds like the fuel level sender was not plugged in.
Or it is too low on fuel. I am guessing that when you pulled the tank, it was down to only a few gallons. This is low enough to turn on the light
Yeap, it was down on fuel and the fuel sensor connector was not plugged in. 5 minute fix.Thanks guys.
