Thank you,,, so when you are just crusing not under load are you still making boost? Or is it bleed off?
Thank you Skydog
Thank you Skydog
promod63
Yes, part throttle light load your blow off valve will be open and dumping unneeded pressure. Now your fuel controller thinks your naturally aspirated. I.E. better fuel mileage and better drive ability.
dilley
promod is right. at light load you can hear the excess presseure being released. also it is more responsive to a throttle chop than w/o bov.
Cool i will buy one. What is the best one to buy?
Thank you Skydog
Thank you Skydog
dilley
hard part is finding one with a flange that will fit on the ic and has a body small enough to keep clearance.
promod63
dilley said:hard part is finding one with a flange that will fit on the ic and has a body small enough to keep clearance.
Who says it has to be mounted on the inter cooler. It can also be divorced. Think about it.
