Twintube
- Dec 12, 2020
- Green Bay
- 2013 Yamaha Nytro M-TX
Well no luck on the LED light issue.Will do.
Did you try another power source separate from the sled? All you need is 12volts.Well no luck on the LED light issue.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
Make sure you are using the proper sensor. And make sure it is not a china knock off. I have had issues with knock off ones.
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
I have a 2016 SR VIPER turbo RTX with an AEM AFR gauge and it's reading --- on idle. I lowered my gem controller to #1 on idle from #4 and gauge still reads --- on idle. Anyone have any ideas on why I'm getting this reading?
Did it ever read correctly?I have a 2016 SR VIPER turbo RTX with an AEM AFR gauge and it's reading --- on idle. I lowered my gem controller to #1 on idle from #4 and gauge still reads --- on idle. Anyone have any ideas on why I'm getting this reading?
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
It did read numbers on the gauge before. It didn't always read --- on my gauge. It idles fine, I cleaned the end of my sensor in the exhaust but still reading ---
Could be bad connection. Usually when o2 fails it shows full lean or higher numbers. But if you run race gas, it will take out 02 sensors faster.It did read numbers on the gauge before. It didn't always read --- on my gauge. It idles fine, I cleaned the end of my sensor in the exhaust but still reading ---
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
I am going to do a few test runs a see my numbers. It only reads --- on idle. Gives numbers once I give it throttle.
Oh that’s strange. Does it have a range that needs to be set. Sometimes some gauges will only read so fat like 10 before it does that unless you can lower a setting.I am going to do a few test runs a see my numbers. It only reads --- on idle. Gives numbers once I give it throttle.
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
Ya it's idling fine. My engagement, midrange, and under boost is reading what mpi says it should. Strange that my idle is the only reading that's messed up.
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
My aem gauge reads 11 to 16
I wonder if anything below 11 it shows - - -
You could search that model see what it says in manual.
Robafly
- Dec 19, 2017
- Sudbury
- 2016 Sr viper rtx
When I turn the key on it shows 14 then drops slowly to around 12 then it goes all the way to 17.9 (which is max on gauge) then ---. And the engine is not running yet. I start the engine and it still reads ---
Try powering it up after the sled is running.When I turn the key on it shows 14 then drops slowly to around 12 then it goes all the way to 17.9 (which is max on gauge) then ---. And the engine is not running yet. I start the engine and it still reads ---
If it goes to full max when 02 is usually shot but I have seen them fault out for. Ignition spikes and are fine if you power them after the machine is running.
