fxnytroxtx
Guest
I think the reason it blew is there had to be frozen water in it, when I revalved my rear shock and the guy showed me the old oil and there was a lot of water in it.
they are basically the same as the elka's ?mewaschuk said:just run down to hygear and get the axis !
Studroes144 said:Ok, this oil was yellow. When I took the shock out I turned it upside down and compressed it prolly 10 times and let it spring back..no rebound at all obviously, it would just spring back instantly but more yellow milky looking oil came out and you could see a lot of water bubbles in it. I took the shock and with all my weight trying at hard as I could to push down so that the shock was fully depressed..I could only get it within 1 and a half inches from being fully depressed. The fox zero pro shock I put in it I could depress it basically all the way. Amazing how stiff these stock shocks are. Going for a ride tomorrow afternoon so curious to see how it handles with the zero pro shock on. The shock was taken off a 2012 f800 snopro and replaced with an lxr shock but I can tell already just by compressing the shocks that the snopro shock is noticeable softer compression
