grumpysanta
NICE 144 HAD THE SAME THING ON BOMBY CARB MODEL.
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
Just an update:
I have two gas filters on order and hope to have them before the weekend. For the price, I'll replace them whether they are dirty or not (hopefully the're plugged!). I also ordered the vacuum lines that go between the fuel pumps and the two PTO side carbs. I installed a tee in these lines for syncing the carbs and I thought that there could be a small vacuum leak around one of the 3 tee connections or maybe the small internal diameter of the tees are interfering with the vacuum to the pumps
As for checking the pumps, I have a gauge that can easily read 1 or 2 pounds. I'm going to test one pump at a time by disconnecting and plugging the fuel rail supply line and hooking the gauge directly to the pump outlet. I should be able to run up the motor on the stand on one pump while verifying the pressure on the other. I will also disconnect the gauge to verify flow. If one of the pumps is acting up, I should be able to see a difference between the two
02ViperMody44, what is a top-hat screen? I have had my carbs apart 3 times but I don't remember seeing any screens in there
Thanks for the suggestions, guys!
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
grumpysanta said:NICE 144 HAD THE SAME THING ON BOMBY CARB MODEL.
144 and mountain skis. Now I can stay on top of the powder instead of diving under like a dolphin!
grumpysanta
some dealers remove them and do NOT replace them ..they just rely on the inline or in tank filter . because they are so small and plug easy .. not all machines have them , but some were in the fuel inlet in carb.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
Here is a link for where the screens are. I'll keep looking for another.
http://www.totallyamaha.net/forums/show ... et-screens)&highlight=viper+top+hat+screens
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Here is the post I did with pictures of how my screens looked.
http://www.totallyamaha.net/forums/show ... fuel+viper
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
Yep, that could be problematic if you didn't know it was there...
Does anyone know if the vec carbs have a screen? I don't remember seeing one and I don't see it on the parts list
I checked the filters in the tank by blowing back through the lines and they appear to be clean but I'll still replace them. I also checked the pumps. They both flow good and seem to generate a bit of pressure when I block the hose with my thumb
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
Check your tank vent line I have had that do the same thing before.Bradford said:Yep, that could be problematic if you didn't know it was there...
IA Rider
- Oct 12, 2009
- Floyd County, IA
- 2017 Ski Doo Enduro 1200
Easy way to see if the vent is plugged is to losen the gas cap then the bog will go away.
