Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
So if I full throttle from a dead stop the sled will just sit there and sputter. Never stops running, just a low RPM sputter. Works perfectly well if got to almost full throttle then on it. I initially thought it was the green secondary spring and twisted it to 6 and 2 but it didn't make any difference (I'm running the new secondary). Could a improper throttle cable adjustment cause it? No codes. Once the track is moving I never have a problem. Maybe go one up in the spring?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Any exhaust or airbox mods? The combo of both really leans it out and can cause a bog off idle. I know with my Skinz can if I HAMMER the throttle it has a pretty noticeable bog right off idle. I need to either roll on the throttle OR rev it up to just under clutch engagement before I hammer it for a good launch. Idle speed has a lot to do with it also, it will tend to be boggy if it's at or below 1700rpm idle.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Have you synced the throttle bodies?
Ruggybuggy
- Sep 1, 2013
Yes airbox mod and exhaust. Haven't sync throttle bodies. I didn't notice it running the pink spring so figured it was the green spring.
Ruggybuggy
- Sep 1, 2013
Also it's Porkchop's motor and he didn't complain of it. Unless he didn't notice it.
porkchop
Only air mod I did was some UNI pods on the box cover, it didn't fall flat.
Maybe needs throttle body sync or bad Canadian fuel?
LOL
LOL
canoehead
- Jan 14, 2011
- NE, Alberta
Maybe you're running too lean with the mods?
Ruggybuggy
- Sep 1, 2013
I just assumed it was the secondary causing it. I'll modify the exhaust to give it some restriction and see if it improves.
Ruggybuggy
- Sep 1, 2013
porkchop said:Only air mod I did was some UNI pods on the box cover, it didn't fall flat.
LOL
Yeah just installed your UNI pods and did a custom exhaust. Maybe I'll try putting my airbox lid on and seeing if it makes a difference.
How's the Nytro? Solve your registration issue?
MikeWalters
I forever had this problem and it was my secondary
Ruggybuggy
- Sep 1, 2013
MikeWalters said:I forever had this problem and it was my secondary
Details please.
porkchop
Reggy title came thru, put 322 miles on it so far.
Love it!
Love it!
MikeWalters
Combination of too stiff of a spring, very dirty helix and belt dust. Also had fouled plugs at the time.
I still get it just ever so slightly now. Dont think Ill ever figure it out. Try a short run with your airbox lid removed and see if it gets better or worse.
I have a PCIII but without an AF meter or Autotune like on the PC5 I really have no easy way of telling if it is fuel related.
Ruggybuggy
- Sep 1, 2013
Well I got rid of my bog. I installed the stock exhaust back on, polished my helix up and installed the green spring back in the secondary and the sleds running very nice now.
3-UP
I thought you were using the pink spring, what's your wot with the green?
