done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
did a wot run last week. when i slowed to make a turn and goosed it a few times around the turn, backfired through muffler. when new it seemed to rpm surge up and down if held at 1-2% throttle while turning around or maneuvering tight spots. still under 500 miles and i would rather rich than lean. maybe tps? i do not get any bog though normally. will check plugs today. anyone know if they are indexed? i'll mark them first anyway.Mine acts like it's going to backfire. And it happens not just upon a dead stop.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
check your secondary clutch , i noticed on the stand that the secondary some times is not coming back all the way into low gear . in most cases it would come back but the odd time it would only allow the belt to only shift 1/4 inch from the top , once u hit the throttle again it would act lazy for a split second , i find the centre bushing seems very sloppy imo . but not sure of the factory specs , i hope someone will look deeper into this , i will report this to my dealer
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Notice this ! And actually could be related to belt blowing IMOcheck your secondary clutch , i noticed on the stand that the secondary some times is not coming back all the way into low gear . in most cases it would come back but the odd time it would only allow the belt to only shift 1/4 inch from the top , once u hit the throttle again it would act lazy for a split second , i find the centre bushing seems very sloppy imo . but not sure of the factory specs , i hope someone will look deeper into this , i will report this to my dealer
tony lawhead
- Jan 25, 2017
- kingsley mi
- 2015 viper
it is your fuel regulator too much psi!!!! adding to much fuel down lowNotice this ! And actually could be related to belt blowing IMO
ccyamaha1
- Dec 17, 2015
- williamsburg MI
- viper ltx le
apex ltx gt
It turned out mine was a fuel pressure regulator, it was pumping 95 psi and is only supposed to be 44-45 psi.
totally different machine now
tony lawhead
- Jan 25, 2017
- kingsley mi
- 2015 viper
sorry guy's not sure why it keeps replying holy crapIt turned out mine was a fuel pressure regulator, it was pumping 95 psi and is only supposed to be 44-45 psi.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
LOL I got it its the fuel regulator.. its all goodsorry guy's not sure why it keeps replying holy crap
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Stock sled or flashed? Your dealer tested and adjusted?It turned out mine was a fuel pressure regulator, it was pumping 95 psi and is only supposed to be 44-45 psi.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Tony, you passed out with your forehead on the send button!!your fuel reg is over psi, adding too much fuel down low!!!!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Now that is diagnostics!! Ha Ha..Tony, you passed out with your forehead on the send button!!
ccyamaha1
- Dec 17, 2015
- williamsburg MI
- viper ltx le
apex ltx gt
Stock sled and yes it was at the dealer for this and Yamaha told them to check the regulator and sure enough it was The problems they replaced it with one that was still in a crate , that was good dealer service if you ask meStock sled or flashed? Your dealer tested and adjusted?
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
That's what all dealers are forced to do it seems. No parts available.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes good service. Thanks for info on what you found
- Apr 14, 2003
- Hessel, Michigan
I still have yet to see a bog, hesitation from my SW or others I ride with. These sleds range from stock to stock ECU/ TP clutch kit, flashed ecu with TP clutch kit and flashed with OSP clutching. Still, no hesitation and even made a video that I need to download to Youtube where I can pull the skis up instantly like the start of a snow-cross race.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Where is the fuel regulator located on the 998?
