Csellors
i have an 07 attack that is stock with 5000 miles on it. I just bought it and it has a bog if you give it a lot of gas off idle. Once it is moving, it is fine. I am going to run some sea foam through it. What else could the issue be? Thanks.
breakinbarrs
- Dec 31, 2007
- Not North Enough,Ashburnham MA
Worn belt,fatigued primary spring.
aceltx09
You say stock, but are you sure air box has not been modified??
wileya
- Nov 30, 2009
- Forest, Ontario
- 15 sr viper rtx se
what about old fuel?? my apex does this every year for a bit. seafoam wont hurt.
mr.pitstop
A little seafoam and a new set of plugs and you'll be all set. It probably just needs some fresh fuel, new plugs and some seat time...
