TC Rides
- Feb 1, 2019
- Wilmette, IL
- 2007 Yamaha Apex GT
All-
Any ideas welcome. I am installing new A Arm bushings on my 07 Apex and cannot get the outside, right side bolts out of the A Arms, both upper and lower bolts refuse to come out. The left side outer came apart (and went back together) easily. I have not done the left inner ones yet.
Obviously, the two A Arms are disconnected from the bulkhead, rotated 90 degrees forward and sitting on work bench. From this orientation, I used a hammer on threaded end of bolt to drive them downward (while supporting below). It almost seems like there is a c clip somewhere preventing these from being removed.
Lastly, anyone ever see a bushing break like below? Was not installed, but found in my hand when I poured out the bag.
Mods, please move this post if there is a better sub-forum for subject.
Thank you
Thank you
RobX-1
- Coldwater, OH
I suspect your a-arm bolts are tweaked and preventing them from sliding out. I had one that was kinked and was a burger to get out; at least the a-arm itself was still good and straight.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Your bolts are likely bent. I have run into that before. I had to use a sawzall with a metal blade to cut the bolt between where the spindle & a-arm meet (down through lip of the bushing) to get the bolt out.
RAMSOMAIR
Yep, one on my brothers Apex was shaped like a Z almost.
Brotherdan
- Sep 8, 2017
- Belmont,maine
The bolts should easily slide right out I would also suspect they are bent & will require careful cutting of the bolts, or stuck in the spindle sleeves, make sure to use a nut on the bolt threads to prevent mushrooming,try some heat with mapp gas just don’t go crazy& lots of penetrating fluid if they are just stuck & you can free them up would be a much better problem than them being bent ,as far as the bushings it could be a quality/ brand issue I’ve only ever used the mpi/yamaha brand & never had any quality issuesAll-
Thank you
i have cracked some putting them in before i started using a threaded rod to do it with big washers. i have only ever used yamaha/ulmers kit when doing it.
i helped a guy do a vector last season and it was lucky i had all the bolts in a spare set of a arms as i needed them. i ended up using a chunk of wood to spread the arms while i used a death wheel to cut the bolts. the fun part was getting the bolts out of the sleeves as both of the ones that stuck split the sleeve at the end that the bolts go through that is in the spindle.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Bolts are rusted to the spindle sleeves, due to lack of maintenance, air hammer them loose.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Mine where not bent but seized in the collars/sleeves had to sawzall them out
