pelo'n
- Jan 3, 2008
Just installed my boondocker turbo---everything went well except for the garbage EFI box pulling an Injector fault on #1. Anyone out there have this problem. Should I just junk the box and get an Attitude or Pure Logic.
Boondocker doesn't seem to want to get off their butts and help. They keep telling me to check the wires.
My sled idles fine without the box---their wires are not my problem.
Any thoughts
Any thoughts
HYFLYR
Ditch the box.
pelo'n
- Jan 3, 2008
Boondocker got back with me. Turns out they had some yahoo wire up the harness and he put some wires on backwards. It should work fine--we'll see Friday. Does anyone have some base settings for the EFI box I can start out with for 12lbs of boost. Running at elevations of 9500 to 11500 ft.
Still might ditch the box
HYFLYR
The have pre set maps in the box. Ask them which one will be close for your riding elevations and go from there. I am at sea level and up but map one was pretty close for me but still needed tuning for sure.
They have 5 maps already set so im sure 1 of them might get you close or at least a good starting point.
