boostedmayhem
- Dec 22, 2015
- idaho
- 2006 yamaha apex turbo
2022 polaris pro matryx slash boost
Hey guys im new to the 4stroke turbos, just bought an 06 yamaha apex with a boondocker turbo, what the problem is recently I noticed oil in the intake side or compression side, when you start it and let it run for a bit you start to see a little oil like the compressor wheel is flinging it out, its not much, but eventually gathers to a small puddle where the intake snorkel slips over the turbo. Anyone had this issue or have any ideas?
thamax
oil seals in turbo are probably bad. the center section can be rebuilt or replaced
boostedmayhem
- Dec 22, 2015
- idaho
Thanks for the reply, so I had been trying to get ahold of boondocker for this problem and they finally responded back and said i probably need a smaller orifice on the oil inlet tube to drop the oil press down going into the turbo, said its probably too high and pushing oil out around the bearings. Which now I wonder if it like you mentioned and the oil seals are bad now beacause of thatoil seals in turbo are probably bad. the center section can be rebuilt or replaced
thamax
You buy the fitting or you can send me yours and i can install the Restrictor i have several on hand. Its cheap then a new chra
boostedmayhem
- Dec 22, 2015
- idaho
Is the fitting on the in or out?You buy the fitting or you can send me yours and i can install the Restrictor i have several on hand. Its cheap then a new chra
.030 orfice was what typically gets installed in the supply line. is the return line kinked, blocked, etc.
boostedmayhem
- Dec 22, 2015
- idaho
No I dont see any where where its kinked. I will try and send a pic of it.030 orfice was what typically gets installed in the supply line. is the return line kinked, blocked, etc.
thamax
goes on the feed line and just screws in
boostedmayhem
- Dec 22, 2015
- idaho
Im having problems getting pics to upload. Does it screw into the line itself or the turbogoes on the feed line and just screws in
thamax
I install the restirctor on the feed line by the motor
boostedmayhem
- Dec 22, 2015
- idaho
Ok,thank you for the help, I really appreciate it.I install the restirctor on the feed line by the motor
thamax
I have replacement center sections in stock so pm me if you need any replacement parts
boostedmayhem
- Dec 22, 2015
- idaho
Ok sounds good, I will try the restirctor first and if that doesnt work and it ends up being that I need to replace the center section I will pm you. Thank you again for all the help, its much appreciatedI have replacement center sections in stock so pm me if you need any replacement parts
