mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I can't hold boost under 25psi... which is too much for me at this moment (engine break in...)
Is it possible my new double downpipe is too restrictive for the wastegate to properly function?
The wastegate side of downpipe has 1" tube that exist directly to atmostphere juste beside the downpipe itself.
Is it possible the wastegate stick close because of the 'wall' between the turbine outlet and wastegate (when metal gets very hot and expand....)
I did a cold test and its not sticking... but its rubbing somewhere I can hear it.
I would like to keep her down to 15-18 psi for the moment until engine is properly broken in.
thank you
thank you
