gas n go
New to the turbo, running low comp, pistons, 260 mcx reflashed to 14psi. Question is, how many pounds over target is typical before settling to actual boost? Ie; target 14 but hits 17 before settling, is this typical and safe?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
You're running the MCX TCV (turbo Control valve)?
I would recomend to edit the boost map to get rid of the overboost condition.
When you hit the trigger, for how long does the boost spike last?
gas n go
The boost spike is only momentary, have a turbo smart controller. I believe it is little more than a needle and seat. Don't even know where to begin with regards to editing the boost map. Thank you.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
How high does it spike?
For how long does the spike last?
One second? More? or Less?
gas n go
-30c minimum boost 7lbs, spikes too 10lbs for a second. Normal?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
That is no problem running low comp pistons, and yes that is normal on many MBC's.
gas n go
Thank you
- 9K
