kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
For what its worth I had ARP head studs and removed them and went stock TTY bolts when I had to swap the head early on by Ulmer. Good luck!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Theoretically, by doing the math, you should be able to run 28ish lbs of boost on Q16 with stock compression. I've pulled a rod out of a motor that was bent like an "S" that never ran over 14 lbs (thank god it didn't snap)! Your fuel & timing will need to be perfect and make sure your fuel is sealed and fresh (not dead fuel) at 20 lbs.
